Ir para o conteúdo principal
HP Elite x2 1012 G2 Battery Replacement
O que você precisa
  1. HP Elite x2 1012 G2 Battery Replacement, Screen: passo 1, imagem 1 %32
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Battery Replacement: passo 2, imagem 1 %32 HP Elite x2 1012 G2 Battery Replacement: passo 2, imagem 2 %32 HP Elite x2 1012 G2 Battery Replacement: passo 2, imagem 3 %32
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Battery Replacement: passo 3, imagem 1 %32 HP Elite x2 1012 G2 Battery Replacement: passo 3, imagem 2 %32
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
    • During reassembly, certain clips/edges may not snap into place properly even with a lot of force. To counteract this, lift the edge up, place the suction cup further inwards on the screen and pull it slightly upwards while pressing the edge of the screen downwards. The edge should snap correctly into the housing.
  4. HP Elite x2 1012 G2 Battery Replacement: passo 4, imagem 1 %32
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Battery Replacement: passo 5, imagem 1 %32 HP Elite x2 1012 G2 Battery Replacement: passo 5, imagem 2 %32 HP Elite x2 1012 G2 Battery Replacement: passo 5, imagem 3 %32
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Battery Replacement: passo 6, imagem 1 %32 HP Elite x2 1012 G2 Battery Replacement: passo 6, imagem 2 %32
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Battery Replacement, Battery: passo 7, imagem 1 %32
    • Orient the device so that the battery is closest to you.
    • The battery is the large, black rectangle at the bottom of the device.
  8. HP Elite x2 1012 G2 Battery Replacement: passo 8, imagem 1 %32 HP Elite x2 1012 G2 Battery Replacement: passo 8, imagem 2 %32
    • Remove all six Phillips 3 mm screws around the battery by rotating in the counterclockwise direction with a Phillips screwdriver.
  9. HP Elite x2 1012 G2 Battery Replacement: passo 9, imagem 1 %32 HP Elite x2 1012 G2 Battery Replacement: passo 9, imagem 2 %32
    • Remove the battery's connector by pushing both sides of the tab towards yourself with a plastic opening tool.
  10. HP Elite x2 1012 G2 Battery Replacement: passo 10, imagem 1 %32
    • Lift the battery out of the device.
Conclusão
16 outras pessoas executaram este guia.
Andy Velazquez
Membro desde: 04/18/18
350 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S18-G5, Livingston Spring 2018 Membro de Cal Poly, Team S18-G5, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G5
4 Membros
Autoria de 13 guias
6 comentários
how do you test the battery? what voltage should it be maintaining?
scott kay - Responder
Hi, after the replacement battery
toch not working, help pls?
Parsa Aghabeikzadeh - Responder
The first "Foil-Connector" in step 5 is for the Touch Feature. Make sure it fits propper!
Anselmbe -
PC not coming on, also not charging.
Abiola - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 12
Últimos 7 dias: 66
Últimos 30 dias: 319
Ao todo: 26,098
