Ir para o conteúdo principal
HP Elite X2 1013 G3 Fan Replacement
O que você precisa
  1. HP Elite X2 1013 G3 Fan Replacement, Screen: passo 1, imagem 1 %32
    • Flip the device over so the base is facing the ceiling.
    • Lift up the tablet stand.
    • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
  2. HP Elite X2 1013 G3 Fan Replacement: passo 2, imagem 1 %32 HP Elite X2 1013 G3 Fan Replacement: passo 2, imagem 2 %32
    • Flip the tablet over with the screen facing upwards.
    • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
    • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
  3. HP Elite X2 1013 G3 Fan Replacement: passo 3, imagem 1 %32 HP Elite X2 1013 G3 Fan Replacement: passo 3, imagem 2 %32
    • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
    • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
  4. HP Elite X2 1013 G3 Fan Replacement: passo 4, imagem 1 %32 HP Elite X2 1013 G3 Fan Replacement: passo 4, imagem 2 %32
    • Remove the screen from the tablet.
  5. HP Elite X2 1013 G3 Fan Replacement, Battery: passo 5, imagem 1 %32
    • Use the Phillips #00 screwdriver to remove the six 2 mm screws.
    • Gently disconnect the two connectors.
  6. HP Elite X2 1013 G3 Fan Replacement: passo 6, imagem 1 %32
    • Lift the battery out of the housing.
  7. HP Elite X2 1013 G3 Fan Replacement, Fan: passo 7, imagem 1 %32
    • Undo the two small connectors by pulling gently.
  8. HP Elite X2 1013 G3 Fan Replacement: passo 8, imagem 1 %32
    • Gently peel up three copper pieces of tape as shown.
    • Do not pull off completely.
  9. HP Elite X2 1013 G3 Fan Replacement: passo 9, imagem 1 %32
    • Use tweezers or your fingers to carefully undo the indicated five connectors.
    • There will be a number of loose components after disconnecting the five connectors. If any are completely detached, set them aside.
  10. HP Elite X2 1013 G3 Fan Replacement: passo 10, imagem 1 %32 HP Elite X2 1013 G3 Fan Replacement: passo 10, imagem 2 %32
    • Using tweezers or your fingers, lift up and remove the plastic covering and set it aside.
  11. HP Elite X2 1013 G3 Fan Replacement: passo 11, imagem 1 %32
    • Unscrew the two speaker/antenna module mounting 2mm screws using a Phillips #00 Screwdriver.
  12. HP Elite X2 1013 G3 Fan Replacement: passo 12, imagem 1 %32 HP Elite X2 1013 G3 Fan Replacement: passo 12, imagem 2 %32 HP Elite X2 1013 G3 Fan Replacement: passo 12, imagem 3 %32
    • Use tweezers or your finger to unclasp and remove the upper right module with the copper tape and wire. Start by popping up the left side of the module.
    • Continue to pry up the module toward the right.
    • At this point, all connectors have been undone in previous steps, but if you notice any wires securing the module, do not keep pulling! Gently undo any connectors before proceeding.
    • Gently lift the whole module out, including the trailing wire.
  13. HP Elite X2 1013 G3 Fan Replacement: passo 13, imagem 1 %32 HP Elite X2 1013 G3 Fan Replacement: passo 13, imagem 2 %32 HP Elite X2 1013 G3 Fan Replacement: passo 13, imagem 3 %32
    • Using a spudger, pry the left black plastic speaker/antenna module off of the frame as pictured. Start by lifting up the right side of the module, then slowly work your way down the module towards the right.
    • The slight cracking sound you will hear is the sounds of plastic clasps.
  14. HP Elite X2 1013 G3 Fan Replacement: passo 14, imagem 1 %32
    • Undo the two indicated connectors near the fan using your fingers or tweezers.
  15. HP Elite X2 1013 G3 Fan Replacement: passo 15, imagem 1 %32
    • Use the Phillips #00 Screwdriver to remove the eight 2 mm screws.
  16. HP Elite X2 1013 G3 Fan Replacement: passo 16, imagem 1 %32 HP Elite X2 1013 G3 Fan Replacement: passo 16, imagem 2 %32
    • Unscrew the single 2mm screw from the peripheral board with the same screwdriver, and remove the peripheral board from the motherboard.
  17. HP Elite X2 1013 G3 Fan Replacement: passo 17, imagem 1 %32 HP Elite X2 1013 G3 Fan Replacement: passo 17, imagem 2 %32
    • Remove the SD Card holder from the motherboard.
  18. HP Elite X2 1013 G3 Fan Replacement: passo 18, imagem 1 %32 HP Elite X2 1013 G3 Fan Replacement: passo 18, imagem 2 %32 HP Elite X2 1013 G3 Fan Replacement: passo 18, imagem 3 %32
    • Using the Phillips 00 Screwdriver, remove the 2mm screw from the ribbon cable bracket.
    • Lift the ribbon cable bracket and connector off of the motherboard.
  19. HP Elite X2 1013 G3 Fan Replacement: passo 19, imagem 1 %32
    • Undo the indicated ribbon connector.
  20. HP Elite X2 1013 G3 Fan Replacement: passo 20, imagem 1 %32 HP Elite X2 1013 G3 Fan Replacement: passo 20, imagem 2 %32
    • Lift up the flap on the right of the indicated plate, and lift the whole covering off.
  21. HP Elite X2 1013 G3 Fan Replacement: passo 21, imagem 1 %32
    • Use tweezers or your fingers to undo the black ribbon connector.
  22. HP Elite X2 1013 G3 Fan Replacement: passo 22, imagem 1 %32
    • Remove the whole assembly, granting access to the fans.
  23. HP Elite X2 1013 G3 Fan Replacement: passo 23, imagem 1 %32
    • Use the Phillips #00 Screwdriver to remove the four 2mm screws.
    • If you are only removing one fan, remove the screws securing only that fan.
  24. HP Elite X2 1013 G3 Fan Replacement: passo 24, imagem 1 %32
    • Lift the fan out.
Conclusão
Hunter Baird-Wise
Membro desde: 04/18/19
447 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S9-G12, Maness Spring 2019 Membro de Cal Poly, Team S9-G12, Maness Spring 2019
CPSU-MANESS-S19S9G12
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 22
Duração total: 1,092
