Ir para o conteúdo principal
HP Elite X2 1013 G3 Battery Replacement
O que você precisa
  1. HP Elite X2 1013 G3 Battery Replacement, Screen: passo 1, imagem 1 %32
    • Flip the device over so the base is facing the ceiling.
    • Lift up the tablet stand.
    • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
  2. HP Elite X2 1013 G3 Battery Replacement: passo 2, imagem 1 %32 HP Elite X2 1013 G3 Battery Replacement: passo 2, imagem 2 %32
    • Flip the tablet over with the screen facing upwards.
    • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
    • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
  3. HP Elite X2 1013 G3 Battery Replacement: passo 3, imagem 1 %32 HP Elite X2 1013 G3 Battery Replacement: passo 3, imagem 2 %32
    • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
    • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
  4. HP Elite X2 1013 G3 Battery Replacement: passo 4, imagem 1 %32 HP Elite X2 1013 G3 Battery Replacement: passo 4, imagem 2 %32
    • Remove the screen from the tablet.
  5. HP Elite X2 1013 G3 Battery Replacement, Battery: passo 5, imagem 1 %32
    • Use the Phillips #00 screwdriver to remove the six 2 mm screws.
    • Gently disconnect the two connectors.
  6. HP Elite X2 1013 G3 Battery Replacement: passo 6, imagem 1 %32
    • Lift the battery out of the housing.
Conclusão
Uma outra pessoa concluiu este guia.
Asmita Sharma
Membro desde: 04/18/19
186 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S9-G12, Maness Spring 2019 Membro de Cal Poly, Team S9-G12, Maness Spring 2019
CPSU-MANESS-S19S9G12
4 Membros
Autoria de 5 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 53
Ao todo: 2,997
