Introdução
Replacing the fan is pretty straight-forward, just be sure you have purchased a replacement which is compatible with the ROVE. This guide also has several steps make sure you have suitable places to store all the components and screws you will be removing during the process and of course, good luck!
O que você precisa
Remove the two black 6.35mm PH #0 screws with a screwdriver from the top of the hard drive.
Remove the two silver 6.35mm PH#0 screws from the bottom of the hard drive.
Remove four 6.35 mm PH#0 screws around the fan using the J1 screwdriver head.
Unplug the fan.
Remove the fan from the computer.
14 outras pessoas executaram este guia.
2 comentários
These instructions serve as a guide to battery replacement as well! I forgot to write down the battery replacement part number - anyone have that handy? Thanks!!
I have a problem, my screen doesn't work and it only makes colors and static. I followed the instructions and after assembling it the screen was no longer working
please where can I get the replacement battery
reply to tosinadedeji@gmail.com
tosinwil - Responder
