Ir para o conteúdo principal
HP ENVY 5530 Front Panel Replacement
O que você precisa
  1. HP ENVY 5530 Front Panel Replacement, Front Panel: passo 1, imagem 1 %32
    • Lift up printer screen.
  2. HP ENVY 5530 Front Panel Replacement: passo 2, imagem 1 %32 HP ENVY 5530 Front Panel Replacement: passo 2, imagem 2 %32 HP ENVY 5530 Front Panel Replacement: passo 2, imagem 3 %32
    • Use the Metal Spudger from the IFIXIT Toolkit to pry the left corner of the front panel.
    • Slowly pry the front panel by sliding the Metal Spudger along the border of the front panel.
  3. HP ENVY 5530 Front Panel Replacement: passo 3, imagem 1 %32 HP ENVY 5530 Front Panel Replacement: passo 3, imagem 2 %32
    • Remove the front panel by lifting each corner up.
    • Replace the front panel.
Conclusão
Elizabeth Surface
Membro desde: 08/26/15
1.465 Reputação
Autoria de 9 guias
Equipe
USF Tampa, Team 4-6, Meier Fall 2015 Membro de USF Tampa, Team 4-6, Meier Fall 2015
USFT-MEIER-F15S4G6
Membros da 4
Autoria de 18 guias
4 comentários
My HP Envy 5530 had a screw hidden beneath the label on the right side of the front panel. I used a knife to lift the label to access the screw.
rndymike - Responder
Is the front panel from a 5532 compatible with the Envy 5530?
Armando Pagan - Responder
Wish I would have seen the comment about the screw… fix your post… at least protect others from making the same mistake
Azpatch - Responder
Where does the cable go?
Victorian Lover - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 23
Últimos 30 dias: 34
Duração total: 2,191
