Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Open the front access panel by placing your finger in the front slot and pulling gently.
Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
Carefully lift the top panel off of the printer.
Do not tear or damage the two cables that connect the top lid to the motherboard.
Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
Remove one 9mm T10 Torx screw from the back of the printer lid.
Press outward on the plastic tab holding the back panel in place.
Pull the back panel towards you and lift it away from the rest of the printer cover.
Remove one 9mm T10 Torx screw from the white retaining tab.
To remove the scanner glass, gently push it towards you.
Slide glass panel until it is completely removed from printer.
3 outras pessoas executaram este guia.
