Ir para o conteúdo principal
HP Deskjet D1660 Rollers Replacement
O que você precisa
  1. HP Deskjet D1660 Rollers Replacement, Top Cover: passo 1, imagem 1 %32
    • Remove the back two 14.0 mm Torx #10 screws.
  2. HP Deskjet D1660 Rollers Replacement: passo 2, imagem 1 %32
    • Lay the printer on its back.
    • Grab the paper tray by its right side and pull it to the left and up.
  3. HP Deskjet D1660 Rollers Replacement: passo 3, imagem 1 %32
    • Open the frontal access panel by lifting it from the top.
    • Similar to the paper tray, grab it from the right side and pull it to the left and up.
  4. HP Deskjet D1660 Rollers Replacement: passo 4, imagem 1 %32 HP Deskjet D1660 Rollers Replacement: passo 4, imagem 2 %32 HP Deskjet D1660 Rollers Replacement: passo 4, imagem 3 %32
    • Take out the two frontal 14.0 mm Torx #10 screws.
    • Carefully lift the frontal cover.
    • Don't lift it up aggressively. A strip will be attached to it.
  5. HP Deskjet D1660 Rollers Replacement, Rollers: passo 5, imagem 1 %32 HP Deskjet D1660 Rollers Replacement, Rollers: passo 5, imagem 2 %32
    • Remove the five 13.0 mm Torx #10 screws found on top of the frame.
    • Remove the four 9.0 mm Torx #10 smaller screws.
  6. HP Deskjet D1660 Rollers Replacement: passo 6, imagem 1 %32 HP Deskjet D1660 Rollers Replacement: passo 6, imagem 2 %32
    • Lift the cover up using both of your hands.
    • Lift it carefully as a strip and motor will be connected to the bottom part of the printer.
  7. HP Deskjet D1660 Rollers Replacement: passo 7, imagem 1 %32 HP Deskjet D1660 Rollers Replacement: passo 7, imagem 2 %32
    • Locate the rollers, which will be on the bottom of the metal frame that holds the carriage.
    • Grab the rollers and remove them by pulling them to one side and lifting them up.
    • Do the same for the other three.
Conclusão
Equipe
Cal Poly, Team 1-41, Maness Winter 2014 Membro de Cal Poly, Team 1-41, Maness Winter 2014
CPSU-MANESS-W14S1G41
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 1,203
