O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Power printer on.
Lift up the lid to the printer using the notch on the right side of the printer to expose the ink cartridges.
Press down gently on the front tab of the ink cartridge that needs replacing and then lift up.
Make sure you have the correct model number of ink that needs to be replaced.
Angle the new ink cartridge to the back and slide it into the slot. Press down gently on the head until you hear a soft click.
Close the lid and allow the printer to recalibrate itself.
3 outras pessoas executaram este guia.
