Ir para o conteúdo principal
HP Deskjet 3522 Ink Cartridge Replacement
  1. HP Deskjet 3522 Ink Cartridge Replacement, Ink Cartridge: passo 1, imagem 1 %32 HP Deskjet 3522 Ink Cartridge Replacement, Ink Cartridge: passo 1, imagem 2 %32
    • Power printer on.
    • Lift up the lid to the printer using the notch on the right side of the printer to expose the ink cartridges.
  2. HP Deskjet 3522 Ink Cartridge Replacement: passo 2, imagem 1 %32 HP Deskjet 3522 Ink Cartridge Replacement: passo 2, imagem 2 %32
    • Press down gently on the front tab of the ink cartridge that needs replacing and then lift up.
  3. HP Deskjet 3522 Ink Cartridge Replacement: passo 3, imagem 1 %32
    • Make sure you have the correct model number of ink that needs to be replaced.
    • For the HP Deskjet 3522 the required ink is HP 564 (Regular or XL)
  4. HP Deskjet 3522 Ink Cartridge Replacement: passo 4, imagem 1 %32 HP Deskjet 3522 Ink Cartridge Replacement: passo 4, imagem 2 %32
    • Angle the new ink cartridge to the back and slide it into the slot. Press down gently on the head until you hear a soft click.
    • Close the lid and allow the printer to recalibrate itself.
Conclusão
3 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 1-30, Donnelly Fall 2014 Membro de USF Tampa, Team 1-30, Donnelly Fall 2014
USFT-DONNELLY-F14S1G30
1 Membro
Autoria de 2 guias
Um comentário
These instructions were perfect to follow and complete.
walterawa1862 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 2,474
