Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Ferramentas
Nenhuma ferramenta especificada.
Peças
  1. Power printer on. Lift up the lid to the printer using the notch on the right side of the printer to expose the ink cartridges.
    • Power printer on.
    • Lift up the lid to the printer using the notch on the right side of the printer to expose the ink cartridges.
  2. Press down gently on the front tab of the ink cartridge that needs replacing and then lift up. Press down gently on the front tab of the ink cartridge that needs replacing and then lift up.
    • Press down gently on the front tab of the ink cartridge that needs replacing and then lift up.
  3. Make sure you have the correct model number of ink that needs to be replaced.
    • Make sure you have the correct model number of ink that needs to be replaced.
    • For the HP Deskjet 3522 the required ink is HP 564 (Regular or XL)
  4. Angle the new ink cartridge to the back and slide it into the slot. Press down gently on the head until you hear a soft click. Close the lid and allow the printer to recalibrate itself.
    • Angle the new ink cartridge to the back and slide it into the slot. Press down gently on the head until you hear a soft click.
    • Close the lid and allow the printer to recalibrate itself.
Conclusão
3 outras pessoas concluíram este guia.
Melinda Singleton
Membro desde: 09-10-2014
182 Reputation
Autoria de 1 guia
Equipe
USF Tampa, Team 1-30, Donnelly Fall 2014 Membro de USF Tampa, Team 1-30, Donnelly Fall 2014
USFT-DONNELLY-F14S1G30
1 Membro
1 Guia de autoria
These instructions were perfect to follow and complete.
walterawa1862 - Responder
Adicione um comentário
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 1,681
