Ir para o conteúdo principal
HP Deskjet 2624 Scanner Glass Replacement
O que você precisa
  1. HP Deskjet 2624 Scanner Glass Replacement, Scanner Glass: passo 1, imagem 1 %32
    • Unplug all cords from the printer, and remove all the paper from the tray.
  2. HP Deskjet 2624 Scanner Glass Replacement: passo 2, imagem 1 %32 HP Deskjet 2624 Scanner Glass Replacement: passo 2, imagem 2 %32
    • Remove the four screws securing the scanner bed module to the printer body with a Torx T5 screwdriver.
  3. HP Deskjet 2624 Scanner Glass Replacement: passo 3, imagem 1 %32
    • Gently pry the scanner bed cover slightly off of the printer at the hinge.
    • Lifting the scanning bed cover to a 45 degree angle may make it easier to remove.
  4. HP Deskjet 2624 Scanner Glass Replacement: passo 4, imagem 1 %32
    • Lift up the scanner bed module and remove the two ribbon cables by pulling them straight out.
    • Set the printer body aside.
  5. HP Deskjet 2624 Scanner Glass Replacement: passo 5, imagem 1 %32 HP Deskjet 2624 Scanner Glass Replacement: passo 5, imagem 2 %32 HP Deskjet 2624 Scanner Glass Replacement: passo 5, imagem 3 %32
    • Separate the plastic halves of the scanner bed by gently pulling the tabs on the clips holding the halves together.
    • Pull the halves apart while undoing the clips to prevent plastic snapping.
  6. HP Deskjet 2624 Scanner Glass Replacement: passo 6, imagem 1 %32 HP Deskjet 2624 Scanner Glass Replacement: passo 6, imagem 2 %32
    • Remove the glass pane from the plastic shell by prying the tabs back that secure the glass, as well as peeling the adhesive apart slowly.
    • Glass edges can be sharp, handle glass and glass shards with gloves.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 36
Duração total: 733
