Ir para o conteúdo principal
HP Deskjet 2624 Motherboard Replacement
O que você precisa
  1. HP Deskjet 2624 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Unplug all cords from the printer and remove the paper.
  2. HP Deskjet 2624 Motherboard Replacement: passo 2, imagem 1 %32 HP Deskjet 2624 Motherboard Replacement: passo 2, imagem 2 %32
    • Using the Torx T5 screwdriver, remove the four screws connecting the scanner bed module to the printer base.
  3. HP Deskjet 2624 Motherboard Replacement: passo 3, imagem 1 %32 HP Deskjet 2624 Motherboard Replacement: passo 3, imagem 2 %32
    • Gently lift the scanner bed module slightly off of the printer base. Be sure to carefully unplug the ribbon cables before fully removing the scanner bed.
    • Unplug the ribbon cables by pulling them gently straight out of their plugs.
  4. HP Deskjet 2624 Motherboard Replacement: passo 4, imagem 1 %32
    • Remove the cables connected to the motherboard by gently pulling them straight out. Do not unplug the cables by pulling on the wires.
    • Unplug the last two ribbons connected to the motherboard by gently pulling them straight out.
    • Be sure to take note of where all plugs and ribbons are connected to the motherboard.
    • Remove the motherboard from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 20
Duração total: 504
