Ir para o conteúdo principal
HP Deskjet 1055 Motherboard Replacement
O que você precisa
  1. HP Deskjet 1055 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 HP Deskjet 1055 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 HP Deskjet 1055 Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Turn off the printer then open the top lid in order to see the inside of the printer.
    • Wait at least 15 minutes after turning off the printer before handling the motherboard.
    • After waiting 15 minutes, locate the blue tabs and gently pull them out of their sockets.
  2. HP Deskjet 1055 Motherboard Replacement: passo 2, imagem 1 %32
    • Locate the three white plugs with wires attached to them. Gently grab the sides of the white chorded plugs and pull them out of their socket.
  3. HP Deskjet 1055 Motherboard Replacement: passo 3, imagem 1 %32 HP Deskjet 1055 Motherboard Replacement: passo 3, imagem 2 %32
    • Using a T-10 Torx screwdriver, unscrew the three 1/2'' screws on the motherboard.
    • Note which screws were taken out of their specific spot because they must me placed back to their original spot.
  4. HP Deskjet 1055 Motherboard Replacement: passo 4, imagem 1 %32
    • Carefully pull the motherboard out of the printer.
Conclusão
In order to reassemble your device, follow these instructions in reverse orders
7 outras pessoas executaram este guia.
Daniel
Membro desde: 10/06/12
314 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 9-18, Amido Fall 2012 Membro de Cal Poly, Team 9-18, Amido Fall 2012
CPSU-AMIDO-F12S9G18
Membros da 4
Autoria de 10 guias
Um comentário
How to open Top part
sunny.2600 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 21
Duração total: 5,243
