Ir para o conteúdo principal
HP Deskjet 1055 Ink Cartridge Replacement
O que você precisa
  1. HP Deskjet 1055 Ink Cartridge Replacement, Ink Cartridge: passo 1, imagem 1 %32
    • Turn on the printer by pressing the power button.
  2. HP Deskjet 1055 Ink Cartridge Replacement: passo 2, imagem 1 %32 HP Deskjet 1055 Ink Cartridge Replacement: passo 2, imagem 2 %32
    • Place your index finger in the opening on the front of the printer (right side below scanner/copier) and pull the door down.
    • Pull down on the tab that lies in the middle of the newly-exposed gray cover.
  3. HP Deskjet 1055 Ink Cartridge Replacement: passo 3, imagem 1 %32
    • The tri-color cartridge sits on the left side; the black cartridge sits on the right.
    • Grab the cartridge from the top and bottom and pull down until it clicks.
    • Pull out the freed cartridge.
  4. HP Deskjet 1055 Ink Cartridge Replacement: passo 4, imagem 1 %32 HP Deskjet 1055 Ink Cartridge Replacement: passo 4, imagem 2 %32 HP Deskjet 1055 Ink Cartridge Replacement: passo 4, imagem 3 %32
    • Take the replacement cartridge out of its packaging and pull off the plastic tab.
    • Do not touch the electrical contacts or ink nozzles. Touching may cause malfunctions.
    • Hold the cartridge on both sides with the title sticker facing upwards.
  5. HP Deskjet 1055 Ink Cartridge Replacement: passo 5, imagem 1 %32 HP Deskjet 1055 Ink Cartridge Replacement: passo 5, imagem 2 %32
    • Slide the cartridge directly into open slot (tri-color on the left, black on the right).
    • Push it forward until you hear it snap.
  6. HP Deskjet 1055 Ink Cartridge Replacement: passo 6, imagem 1 %32
    • Close the gray access door.
  7. HP Deskjet 1055 Ink Cartridge Replacement: passo 7, imagem 1 %32 HP Deskjet 1055 Ink Cartridge Replacement: passo 7, imagem 2 %32
    • Wait 30 seconds for the alignment page to print.
    • Open up the scanner lid and place the alignment page face-down in the right-front corner of the glass.
    • Close the lid.
  8. HP Deskjet 1055 Ink Cartridge Replacement: passo 8, imagem 1 %32
    • Press the color copy button to begin scan.
    • Wait until the power button stops blinking.
Conclusão
When the power button stops blinking, your can now use your printer.
4 outras pessoas executaram este guia.
Daniel
Membro desde: 10/06/12
314 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 9-18, Amido Fall 2012 Membro de Cal Poly, Team 9-18, Amido Fall 2012
CPSU-AMIDO-F12S9G18
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 23
Duração total: 15,990
