Ir para o conteúdo principal
HP Deskjet 1000 J110a Power Button Replacement
O que você precisa
  1. HP Deskjet 1000 J110a Power Button Replacement, Cover Removal: passo 1, imagem 1 %32 HP Deskjet 1000 J110a Power Button Replacement, Cover Removal: passo 1, imagem 2 %32 HP Deskjet 1000 J110a Power Button Replacement, Cover Removal: passo 1, imagem 3 %32
    • Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
  2. HP Deskjet 1000 J110a Power Button Replacement: passo 2, imagem 1 %32 HP Deskjet 1000 J110a Power Button Replacement: passo 2, imagem 2 %32 HP Deskjet 1000 J110a Power Button Replacement: passo 2, imagem 3 %32
    • In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
  3. HP Deskjet 1000 J110a Power Button Replacement: passo 3, imagem 1 %32
    • With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
  4. HP Deskjet 1000 J110a Power Button Replacement, Power Button: passo 4, imagem 1 %32 HP Deskjet 1000 J110a Power Button Replacement, Power Button: passo 4, imagem 2 %32 HP Deskjet 1000 J110a Power Button Replacement, Power Button: passo 4, imagem 3 %32
    • Carefully hold the small clip back to release the button arm.
    • Once the arm is unclipped, gently lift and pull the button until it disconnects at the hinge slot.
    • Replace the old power button with a new one.
Conclusão
Colin Tourjee
Membro desde: 01/29/18
632 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S5-G3, Passmore Spring 2018 Membro de USF Tampa, Team S5-G3, Passmore Spring 2018
USFT-PASSMORE-S18S5G3
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 374
