Ir para o conteúdo principal
HP Deskjet 1000 J110a Plug Ports Replacement
O que você precisa
  1. HP Deskjet 1000 J110a Plug Ports Replacement, Cover Removal: passo 1, imagem 1 %32 HP Deskjet 1000 J110a Plug Ports Replacement, Cover Removal: passo 1, imagem 2 %32 HP Deskjet 1000 J110a Plug Ports Replacement, Cover Removal: passo 1, imagem 3 %32
    • Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
  2. HP Deskjet 1000 J110a Plug Ports Replacement: passo 2, imagem 1 %32 HP Deskjet 1000 J110a Plug Ports Replacement: passo 2, imagem 2 %32 HP Deskjet 1000 J110a Plug Ports Replacement: passo 2, imagem 3 %32
    • In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
  3. HP Deskjet 1000 J110a Plug Ports Replacement: passo 3, imagem 1 %32
    • With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
  4. HP Deskjet 1000 J110a Plug Ports Replacement, Plug Ports: passo 4, imagem 1 %32 HP Deskjet 1000 J110a Plug Ports Replacement, Plug Ports: passo 4, imagem 2 %32 HP Deskjet 1000 J110a Plug Ports Replacement, Plug Ports: passo 4, imagem 3 %32
    • Locate and remove the two flat ribbon connectors which connect the circuit board to the other printer components.
    • Remove each connector using tweezers if it is too difficult to remove them by hand.
  5. HP Deskjet 1000 J110a Plug Ports Replacement: passo 5, imagem 1 %32 HP Deskjet 1000 J110a Plug Ports Replacement: passo 5, imagem 2 %32
    • Locate and remove the three multicolored wire connectors which connect the circuit board to the other printer components.
    • Remove each connector by hand, as shown. You can use tweezers if it is too difficult to remove them by hand.
  6. HP Deskjet 1000 J110a Plug Ports Replacement: passo 6, imagem 1 %32 HP Deskjet 1000 J110a Plug Ports Replacement: passo 6, imagem 2 %32 HP Deskjet 1000 J110a Plug Ports Replacement: passo 6, imagem 3 %32
    • Remove the top two 13mm screws using a screwdriver with the T10 torx bit.
    • Remove the bottom 9mm screw using a screwdriver with the T10 torx bit, and remove the plug port circuit board.
Conclusão
Uma outra pessoa concluiu este guia.
Chris Perez
Membro desde: 01/29/18
247 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S5-G3, Passmore Spring 2018 Membro de USF Tampa, Team S5-G3, Passmore Spring 2018
USFT-PASSMORE-S18S5G3
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 611
