Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
If your printer is not dispensing paper, and it makes no sense, the Paper Control Sensor may not be sensing the paper. The Paper Control Sensor is soldered to a small circuit board. Be careful when handling electronic circuits to avoid damaging it or to avoid damaging yourself. This guide will walk you through on how to replace the Paper Control Sensor.
O que você precisa
Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
Locate the paper control sensor.
Locate and unplug the connector which connects the sensor board to the main circuit board.
