Ir para o conteúdo principal
HP Compaq nc8430 RAM Replacement
O que você precisa
  1. HP Compaq nc8430 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Completely shut down the device and unplug any adapters and cords connected to the device.
    • Carefully flip the device over so that the bottom is facing up.
    • Slide both of the latches to the left.
  2. HP Compaq nc8430 RAM Replacement: passo 2, imagem 1 %32
    • Slide up against the three lines the battery has.
  3. HP Compaq nc8430 RAM Replacement: passo 3, imagem 1 %32
    • Slide the battery up and away from the laptop.
    • Slowly remove the battery to prevent any connectors from getting damaged.
  4. HP Compaq nc8430 RAM Replacement, Remove RAM cover: passo 4, imagem 1 %32
    • Completely shut down the device and unplug any adapters and chords that are connected.
  5. HP Compaq nc8430 RAM Replacement: passo 5, imagem 1 %32
    • Use a screwdriver to remove the single screw on the covering located on the back of the laptop.
  6. HP Compaq nc8430 RAM Replacement, Locate RAM: passo 6, imagem 1 %32
    • Locate the RAM after you remove the covering.
  7. HP Compaq nc8430 RAM Replacement, Push clamps aside: passo 7, imagem 1 %32
    • Use fingers or tools to press the clamps that hold the RAM in to the side.
  8. HP Compaq nc8430 RAM Replacement, Pull RAM up to remove: passo 8, imagem 1 %32
    • Place your fingers firmly on the RAM and pull it up.
  9. HP Compaq nc8430 RAM Replacement, Remove RAM: passo 9, imagem 1 %32
    • Place fingers firmly on RAM and pull it to remove it.
Conclusão
bryan ingram
Membro desde: 03/27/17
101 Reputação
Autoria de 1 guia
Equipe
Texas Tech, Team S13-G4, Bennett Spring 2017 Membro de Texas Tech, Team S13-G4, Bennett Spring 2017
TTU-BENNETT-S17S13G4
Membros da 5
Autoria de 5 guias
Um comentário
umm fine, except there is another module under the keyboard , rather an important fact to be overlooking
bari - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 742
