Ir para o conteúdo principal
HP Compaq nc6400 Screen Replacement
O que você precisa
  1. HP Compaq nc6400 Screen Replacement, Battery: passo 1, imagem 1 %32
    • Turn off and unplug laptop.
  2. HP Compaq nc6400 Screen Replacement: passo 2, imagem 1 %32
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
  3. HP Compaq nc6400 Screen Replacement: passo 3, imagem 1 %32
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
    10.8 volt ????
    OK ?
    Gilbert Baum - Responder
    the volt is 10.8,,?
  4. HP Compaq nc6400 Screen Replacement: passo 4, imagem 1 %32
    • Once both the battery locks are unlocked, slide the battery out to remove.
  5. HP Compaq nc6400 Screen Replacement, Screen: passo 5, imagem 1 %32
    • Remove the four 1.2mm Philips #1 screws attaching the plastic cover to the monitor.
    • The screws may have a small, black plastic cover that lays flush with the screen. Remove these using a pointed tool such as the spudger or philips head screwdriver by prying them out.
  6. HP Compaq nc6400 Screen Replacement: passo 6, imagem 1 %32
    • Remove the four 1.2 Philips #1 screws attaching the face plate to the body.
  7. HP Compaq nc6400 Screen Replacement: passo 7, imagem 1 %32 HP Compaq nc6400 Screen Replacement: passo 7, imagem 2 %32 HP Compaq nc6400 Screen Replacement: passo 7, imagem 3 %32
    • Pry up the plastic screen cover using a pry tool.
    • Keeping the pry tool under the trim, slide it around the entire screen until the the cover has completely detached from the base.
    • You might need to slide the display clip on the top of the screen in order to fully remove the plastic cover.
  8. HP Compaq nc6400 Screen Replacement: passo 8, imagem 1 %32 HP Compaq nc6400 Screen Replacement: passo 8, imagem 2 %32
    • Remove the two 1.2 Philips #1 screws holding down the sensor board at the bottom of the monitor.
  9. HP Compaq nc6400 Screen Replacement: passo 9, imagem 1 %32
    • Remove the right-most 1.2mm Philips #1 screw on the bottom of the monitor.
  10. HP Compaq nc6400 Screen Replacement: passo 10, imagem 1 %32 HP Compaq nc6400 Screen Replacement: passo 10, imagem 2 %32
    • Without lifting the bottom of the monitor, gently flip the screen and lay it face down on the keyboard.
  11. HP Compaq nc6400 Screen Replacement: passo 11, imagem 1 %32 HP Compaq nc6400 Screen Replacement: passo 11, imagem 2 %32
    • Remove the tape holding down the video cable to the monitor.
    • Gently pull out the video cable from the monitor.
  12. HP Compaq nc6400 Screen Replacement: passo 12, imagem 1 %32 HP Compaq nc6400 Screen Replacement: passo 12, imagem 2 %32
    • Remove the monitor's power cable from the sensor board.
    • This is the cable on the farthest right of the sensor board.
  13. HP Compaq nc6400 Screen Replacement: passo 13, imagem 1 %32 HP Compaq nc6400 Screen Replacement: passo 13, imagem 2 %32
    • Once all cables attaching the casing to the monitor have been disconnected, remove the entire screen from the computer and lay it on a flat surface.
    • Remove the four 1.2 Philips #1 screws attaching the bezel to the right side of the monitor.
    • Attach bezel to replacement screen.
Conclusão
4 outras pessoas executaram este guia.
Luis Vazquez
Membro desde: 09/24/13
401 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 14-6, Forte Fall 2013 Membro de Cal Poly, Team 14-6, Forte Fall 2013
CPSU-FORTE-F13S14G6
5 Membros
Autoria de 5 guias
Um comentário
Nicely done. Thanks?
Peter Q. - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 23
Ao todo: 5,478
