Ir para o conteúdo principal
HP Compaq nc6400 RAM Replacement
O que você precisa
  1. HP Compaq nc6400 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Turn off and unplug laptop.
  2. HP Compaq nc6400 RAM Replacement: passo 2, imagem 1 %32
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
  3. HP Compaq nc6400 RAM Replacement: passo 3, imagem 1 %32
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
  4. HP Compaq nc6400 RAM Replacement: passo 4, imagem 1 %32
    • Once both the battery locks are unlocked, slide the battery out to remove.
  5. HP Compaq nc6400 RAM Replacement, RAM: passo 5, imagem 1 %32 HP Compaq nc6400 RAM Replacement, RAM: passo 5, imagem 2 %32
    • Remove the 1.2 Philips #1 screw holding down the RAM cover to the body.
  6. HP Compaq nc6400 RAM Replacement: passo 6, imagem 1 %32
    • Once the screw is removed, use a spudger to pry open the case covering the RAM chip.
  7. HP Compaq nc6400 RAM Replacement: passo 7, imagem 1 %32 HP Compaq nc6400 RAM Replacement: passo 7, imagem 2 %32
    • Use a plastic opening tool to pull back the white clip holding the RAM chip in place.
    • Once the plastic opening tool has disengaged the clip from the RAM chip, keep the plastic opening tool locked into place.
  8. HP Compaq nc6400 RAM Replacement: passo 8, imagem 1 %32
    • With a second plastic opening tool,repeat the above process
    • After both plastic opening tools have been locked in place, the RAM chip should pop out about 1/4 of a inch.
  9. HP Compaq nc6400 RAM Replacement: passo 9, imagem 1 %32 HP Compaq nc6400 RAM Replacement: passo 9, imagem 2 %32
    • The RAM chip is susceptible to static electricity. Before grabbing the RAM chip, make sure you have discharged the electricity from your hands by touching a metal surface other than your computer.
    • Grab the RAM chip with your thumb and index finger
    • Carefully pull the RAM chip out
Conclusão
5 outras pessoas executaram este guia.
Luis Vazquez
Membro desde: 09/24/13
401 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 14-6, Forte Fall 2013 Membro de Cal Poly, Team 14-6, Forte Fall 2013
CPSU-FORTE-F13S14G6
5 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 15
Ao todo: 4,625
