Ir para o conteúdo principal
HP Compaq nc6400 Optical Drive Replacement
O que você precisa
  1. HP Compaq nc6400 Optical Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn off and unplug laptop.
  2. HP Compaq nc6400 Optical Drive Replacement: passo 2, imagem 1 %32
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
  3. HP Compaq nc6400 Optical Drive Replacement: passo 3, imagem 1 %32
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
  4. HP Compaq nc6400 Optical Drive Replacement: passo 4, imagem 1 %32
    • Once both the battery locks are unlocked, slide the battery out to remove.
  5. HP Compaq nc6400 Optical Drive Replacement, Optical Drive: passo 5, imagem 1 %32 HP Compaq nc6400 Optical Drive Replacement, Optical Drive: passo 5, imagem 2 %32
    • Remove the 4 mm P0 Phillips-head screw indicated by the icon of a lock and disk.
  6. HP Compaq nc6400 Optical Drive Replacement: passo 6, imagem 1 %32 HP Compaq nc6400 Optical Drive Replacement: passo 6, imagem 2 %32
    • Press and release the eject icon to partially eject the optical drive.
    • Use of a spudger may be necessary to pry open the optical drive.
  7. HP Compaq nc6400 Optical Drive Replacement: passo 7, imagem 1 %32
    • Grasp the sides and pull the optical drive out.
Conclusão
Chad Williams
Membro desde: 09/30/13
252 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 14-6, Forte Fall 2013 Membro de Cal Poly, Team 14-6, Forte Fall 2013
CPSU-FORTE-F13S14G6
5 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 15
Ao todo: 4,676
