Ir para o conteúdo principal
HP Compaq Presario cq62-214nr RAM Replacement
O que você precisa
  1. HP Compaq Presario cq62-214nr RAM Replacement, Battery: passo 1, imagem 1 %32 HP Compaq Presario cq62-214nr RAM Replacement, Battery: passo 1, imagem 2 %32
    • It is advised to work on this device only when it is OFF, to avoid electrocution risks. Please make sure your laptop is powered off.
    • On the underside of the battery, there is lock that keeps the battery in place. Using your finger, slide the battery lock to unlock the battery. When you have unlocked it, just lift the battery to remove it.
    • We do not have a battery on our device to show how to take it off.
  2. HP Compaq Presario cq62-214nr RAM Replacement, RAM: passo 2, imagem 1 %32 HP Compaq Presario cq62-214nr RAM Replacement, RAM: passo 2, imagem 2 %32
    • Remove the three M2.5x5 mm Phillips screws securing the memory case.
  3. HP Compaq Presario cq62-214nr RAM Replacement: passo 3, imagem 1 %32 HP Compaq Presario cq62-214nr RAM Replacement: passo 3, imagem 2 %32
    • Using a plastic opening tool, insert it alongside any openings on the case. Lift and slide the tool to remove the case.
  4. HP Compaq Presario cq62-214nr RAM Replacement: passo 4, imagem 1 %32 HP Compaq Presario cq62-214nr RAM Replacement: passo 4, imagem 2 %32
    • Remove the top RAM chip by lifting up and pulling it towards the left.
    • Once the top RAM chip is removed, remove the one underneath using the same method.
Conclusão
Roth Marcelin
Membro desde: 10/06/16
726 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 2-6, Sullivan Fall 2016 Membro de USF Tampa, Team 2-6, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G6
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 585
