Introdução
In this guide it will take you through the process of replacing the motherboard. Please make sure the screws from the prerequisite guides are removed.
O que você precisa
With all the screws removed from the previous guides. Remove the final eight M2.5X5 mm Philips screws on the back of the laptop
Remove the four M2.5x5 mm Phillips screws from the exposed keyboard cover.
3 outras pessoas executaram este guia.
