Ir para o conteúdo principal
HP Compaq Presario cq62-214nr Motherboard Replacement
O que você precisa
  1. HP Compaq Presario cq62-214nr Motherboard Replacement, Keyboard: passo 1, imagem 1 %32 HP Compaq Presario cq62-214nr Motherboard Replacement, Keyboard: passo 1, imagem 2 %32
    • With all the screws removed from the previous guides. Remove the final eight M2.5X5 mm Philips screws on the back of the laptop
  2. HP Compaq Presario cq62-214nr Motherboard Replacement: passo 2, imagem 1 %32 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 2, imagem 2 %32
    • In the battery housing, there are three screws that hold the keyboard on. These screws are located on the side near the front.
    • In the center of the bottom of the computer between the RAM and the wifi antenna is a 4th keyboard screw that also needs to be removed.
  3. HP Compaq Presario cq62-214nr Motherboard Replacement: passo 3, imagem 1 %32 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 3, imagem 2 %32 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 3, imagem 3 %32
    • Open up the front of the laptop. Use a plastic opening tool to carefully pry open the keyboard from the edges.
  4. HP Compaq Presario cq62-214nr Motherboard Replacement: passo 4, imagem 1 %32
    • Remove the keyboard by pulling on it with your hands.
    • There is a ribbon cable that is still connected on the back of the keyboard. Do not pull off the ribbon cable when pulling up the keyboard.
  5. HP Compaq Presario cq62-214nr Motherboard Replacement: passo 5, imagem 1 %32 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 5, imagem 2 %32 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 5, imagem 3 %32
    • Locate the keyboard cable/wire that attaches the keyboard to the laptop .
    • Locate the latch of the wire connector
    • Unlatch the wire connector and gently pull out the wire with your hands
  6. HP Compaq Presario cq62-214nr Motherboard Replacement, Motherboard: passo 6, imagem 1 %32
    • Remove the four M2.5x5 mm Phillips screws from the exposed keyboard cover.
  7. HP Compaq Presario cq62-214nr Motherboard Replacement: passo 7, imagem 1 %32 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 7, imagem 2 %32 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 7, imagem 3 %32
    • Locate the three tab holding down the cover of the Motherboard.
    • Lift the tabs with using either a plastic opening tool or your fingers.
  8. HP Compaq Presario cq62-214nr Motherboard Replacement: passo 8, imagem 1 %32 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 8, imagem 2 %32
    • Using a plastic opening tool to lift the sides of the cover.
  9. HP Compaq Presario cq62-214nr Motherboard Replacement: passo 9, imagem 1 %32 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 9, imagem 2 %32 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 9, imagem 3 %32
    • Use your hands to gently lift the cover off.
  10. HP Compaq Presario cq62-214nr Motherboard Replacement: passo 10, imagem 1 %32 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 10, imagem 2 %32 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 10, imagem 3 %32
    • Locate the four cables securing the Motherboard.
    • Gently pull cables to unsecure them.
  11. HP Compaq Presario cq62-214nr Motherboard Replacement: passo 11, imagem 1 %32 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 11, imagem 2 %32 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 11, imagem 3 %32
    • Remove the three M2.25x5 mm Phillips screws.
  12. HP Compaq Presario cq62-214nr Motherboard Replacement: passo 12, imagem 1 %32 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 12, imagem 2 %32 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 12, imagem 3 %32
    • Unlatch the final cable and gently remove the Motherboard.
Conclusão
3 outras pessoas executaram este guia.
Roth Marcelin
Membro desde: 10/06/16
726 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 2-6, Sullivan Fall 2016 Membro de USF Tampa, Team 2-6, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G6
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 16
Duração total: 1,065
