Ir para o conteúdo principal
HP Compaq Presario V5303NR RAM Stick Replacement
O que você precisa
  1. HP Compaq Presario V5303NR RAM Stick Replacement, RAM Stick: passo 1, imagem 1 %32 HP Compaq Presario V5303NR RAM Stick Replacement, RAM Stick: passo 1, imagem 2 %32 HP Compaq Presario V5303NR RAM Stick Replacement, RAM Stick: passo 1, imagem 3 %32
    • Turn laptop bottom-side up.
    • Push the battery latch to the left position to unlock the battery.
    • Lift the battery out of its socket.
    • Failure to unplug the computer and remove the battery can result in electrical discharges on contact with the computer's components. This can damage the computer or even hurt the user.
  2. HP Compaq Presario V5303NR RAM Stick Replacement: passo 2, imagem 1 %32 HP Compaq Presario V5303NR RAM Stick Replacement: passo 2, imagem 2 %32
    • Use the Phillips #0 Screwdriver to remove the 2 5mm screws.
  3. HP Compaq Presario V5303NR RAM Stick Replacement: passo 3, imagem 1 %32
    • Remove the plastic cover panel.
  4. HP Compaq Presario V5303NR RAM Stick Replacement: passo 4, imagem 1 %32 HP Compaq Presario V5303NR RAM Stick Replacement: passo 4, imagem 2 %32
    • Remove the circular, black piece of plastic shown in the picture by pulling it away from the air vent.
    • Use the Phillips #00 screwdriver to loosen, but not remove, the two 4mm screws shown in the picture.
  5. HP Compaq Presario V5303NR RAM Stick Replacement: passo 5, imagem 1 %32
    • Lift open the metal access hatch.
  6. HP Compaq Presario V5303NR RAM Stick Replacement: passo 6, imagem 1 %32 HP Compaq Presario V5303NR RAM Stick Replacement: passo 6, imagem 2 %32
    • Pull the highlighted latches away from the sides of the RAM Stick to unlock it.
  7. HP Compaq Presario V5303NR RAM Stick Replacement: passo 7, imagem 1 %32
    • Pull the RAM Stick toward the metal cover's hinge to unplug the RAM stick.
    • Be gentle when removing or installing the RAM. If it breaks, it could damage the adapter that the RAM plugs into.
  8. HP Compaq Presario V5303NR RAM Stick Replacement: passo 8, imagem 1 %32
    • Carefully remove the unplugged RAM stick through the access hatch.
Conclusão
Chris Obesky
Membro desde: 03/16/18
617 Reputação
Autoria de 3 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Ao todo: 328
