Ir para o conteúdo principal
HP Compaq Presario V5303NR Disk Drive Replacement
O que você precisa
  1. HP Compaq Presario V5303NR Disk Drive Replacement, Disk Drive: passo 1, imagem 1 %32 HP Compaq Presario V5303NR Disk Drive Replacement, Disk Drive: passo 1, imagem 2 %32 HP Compaq Presario V5303NR Disk Drive Replacement, Disk Drive: passo 1, imagem 3 %32
    • Turn the laptop bottom-side up.
    • Push the battery latch to the left position to unlock the battery.
    • Remove the battery from its socket.
    • Failure to unplug the computer and remove the battery can result in electrical discharges on contact with the computer's components. This can damage the computer or even hurt the user.
  2. HP Compaq Presario V5303NR Disk Drive Replacement: passo 2, imagem 1 %32 HP Compaq Presario V5303NR Disk Drive Replacement: passo 2, imagem 2 %32
    • Use the Phillips #0 screwdriver to remove the 3 5mm #0 screws highlighted in the picture.
    • Use the Phillips #0 screwdriver to remove the 2 4mm #0 screws highlighted in the picture.
    • Use the Phippips #0 screwdriver to remove the 10 5mm #0 screws highlighted in the picture.
    • Keep the different types of screws separate from one another. They will only fit into holes created for screws of their size, and thus cannot fit into other screw holes.
  3. HP Compaq Presario V5303NR Disk Drive Replacement: passo 3, imagem 1 %32 HP Compaq Presario V5303NR Disk Drive Replacement: passo 3, imagem 2 %32
    • Remove the laptops bottom panel.
  4. HP Compaq Presario V5303NR Disk Drive Replacement: passo 4, imagem 1 %32
    • Gently remove the disk drive from its socket.
Conclusão
Christopher M Paiva
Membro desde: 03/19/18
109 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 170
