Ir para o conteúdo principal
HP Compaq Presario V5303NR Battery Replacement
  1. HP Compaq Presario V5303NR Battery Replacement, Battery: passo 1, imagem 1 %32 HP Compaq Presario V5303NR Battery Replacement, Battery: passo 1, imagem 2 %32
    • A switch is located below the battery, take your finger and push it over to the left.
    • The instruction to push the latch to the left is only relevant to the first image. The second image, which was included to provide a clearer image of said latch, would have the latch pushed to the right.
    • After this the battery should pop up and be dislodged
  2. HP Compaq Presario V5303NR Battery Replacement: passo 2, imagem 1 %32
    • Remove the battery from its socket.
Conclusão
Ryan Dunn
Membro desde: 03/18/18
197 Reputação
Autoria de 1 guia
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Ao todo: 141
