Introdução
This guide demonstrates how to take out the keyboard from your laptop and replace it with a new one.
O que você precisa
Make sure the laptop is powered OFF. Gently turn the laptop over and place it on a flat surface.
Locate the battery EJECT latch.
Use a Phillip's #00 screwdriver to remove all of the circled screws. Apply moderate pressure to each screw to avoid stripping it.
The three screws circled in red are 9mm Phillip's #00 screws.
The three screws circle in orange are 5mm Phillip's #00 screws.
The three screws circled in yellow are 6mm Phillip's #00 screws.
