Ir para o conteúdo principal
HP Compaq Presario CQ56-110US CD Drive Replacement
O que você precisa
  1. HP Compaq Presario CQ56-110US CD Drive Replacement, CD Drive: passo 1, imagem 1 %32 HP Compaq Presario CQ56-110US CD Drive Replacement, CD Drive: passo 1, imagem 2 %32
    • Loosen the two indicated screws on the panel using a Phillips screwdriver with a PH1 head size.
    • The screws do not come free from the panel. They only need to be loosened enough so that the panel can be lifted/pried using a plastic opening tool.
  2. HP Compaq Presario CQ56-110US CD Drive Replacement: passo 2, imagem 1 %32
    • Use the screwdriver to unscrew the four 5mm screws holding down the hard drive.
  3. HP Compaq Presario CQ56-110US CD Drive Replacement: passo 3, imagem 1 %32 HP Compaq Presario CQ56-110US CD Drive Replacement: passo 3, imagem 2 %32
    • Use plastic opening tools to lift up the hard drive. Set aside the hard drive without disconnecting the wire.
  4. HP Compaq Presario CQ56-110US CD Drive Replacement: passo 4, imagem 1 %32
    • Use a Phillips screwdriver with a PH0 head type to unscrew the indicated 5.5mm screw.
  5. HP Compaq Presario CQ56-110US CD Drive Replacement: passo 5, imagem 1 %32
    • Use plastic opening tools to pry open the CD Drive.
  6. HP Compaq Presario CQ56-110US CD Drive Replacement: passo 6, imagem 1 %32
    • Use your hands to pull the CD drive out and remove it from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Iyonna L. Tynes
Membro desde: 02/15/17
446 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 8-4, Eyestone Spring 2017 Membro de USF Tampa, Team 8-4, Eyestone Spring 2017
USFT-EYESTONE-S17S8G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 811
