Introdução
Should the monitor of your HP Compaq NC6120 laptop stop functioning correctly, you may need to replace the monitor altogether. This is a simple replacement that can be done by removing a few easy screws.
O que você precisa
Locate and remove four black 5.1mm Phillips #1 screws from the left and right sides of the monitor.
Uma outra pessoa concluiu este guia.
