Ir para o conteúdo principal
HP Compaq CQ58-bf9WM Battery Replacement
  1. HP Compaq CQ58-bf9WM Battery Replacement, Battery: passo 1, imagem 1 %32 HP Compaq CQ58-bf9WM Battery Replacement, Battery: passo 1, imagem 2 %32 HP Compaq CQ58-bf9WM Battery Replacement, Battery: passo 1, imagem 3 %32
    • Place thumb on the battery switch and push to slide. The battery will eject.
    • Replace and discard old battery with a new working battery.
Conclusão
pop battery back into place- no tools required
Uma outra pessoa concluiu este guia.
Um comentário
can you help me please? I have a Compaq cq58 and the battery is jammed in, as the battery release button hasn’t flipped back to where it should be. It won’t budge and i need to get the battery off as i have to change the screen - and don’t want any power getting to any of the laptop components!
cliff pooley - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 15
Ao todo: 1,495
