Ir para o conteúdo principal
HP Compaq C700 Touchpad Replacement
O que você precisa
  1. HP Compaq C700 Touchpad Replacement, Keyboard: passo 1, imagem 1 %32
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
  2. HP Compaq C700 Touchpad Replacement: passo 2, imagem 1 %32 HP Compaq C700 Touchpad Replacement: passo 2, imagem 2 %32 HP Compaq C700 Touchpad Replacement: passo 2, imagem 3 %32
    • Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
    • Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
  3. HP Compaq C700 Touchpad Replacement: passo 3, imagem 1 %32
    • Gently lift up and remove the keyboard.
  4. HP Compaq C700 Touchpad Replacement, Touchpad: passo 4, imagem 1 %32
    • Locate the twenty 3 mm Phillips head screws.
    • Unscrew them using the PH0 screwdriver.
  5. HP Compaq C700 Touchpad Replacement: passo 5, imagem 1 %32
    • Remove the hard drive by pulling on the plastic tab and lifting upward.
  6. HP Compaq C700 Touchpad Replacement: passo 6, imagem 1 %32
    • Locate and unscrew the two Phillips head 3 mm screws on the wireless card.
  7. HP Compaq C700 Touchpad Replacement: passo 7, imagem 1 %32
    • Unhook the two wires connecting to the wireless card by gently pulling them out.
  8. HP Compaq C700 Touchpad Replacement: passo 8, imagem 1 %32
    • Gently lift and pull out the card.
  9. HP Compaq C700 Touchpad Replacement: passo 9, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Locate the power button connector wire.
    • Using the tweezers, unhook the wire.
  10. HP Compaq C700 Touchpad Replacement: passo 10, imagem 1 %32 HP Compaq C700 Touchpad Replacement: passo 10, imagem 2 %32
    • Press and hold the lock to pop the panel piece above the keyboard and pull up to remove it.
  11. HP Compaq C700 Touchpad Replacement: passo 11, imagem 1 %32 HP Compaq C700 Touchpad Replacement: passo 11, imagem 2 %32 HP Compaq C700 Touchpad Replacement: passo 11, imagem 3 %32
    • Unplug the remaining wires using the tweezers.
  12. HP Compaq C700 Touchpad Replacement: passo 12, imagem 1 %32
    • Gently pull out the three wires.
  13. HP Compaq C700 Touchpad Replacement: passo 13, imagem 1 %32 HP Compaq C700 Touchpad Replacement: passo 13, imagem 2 %32
    • Locate the four 3 mm Phillips head screws.
  14. HP Compaq C700 Touchpad Replacement: passo 14, imagem 1 %32
    • Unhook the display connector wire.
  15. HP Compaq C700 Touchpad Replacement: passo 15, imagem 1 %32
    • Gently disconnect the display by pulling it upwards.
  16. HP Compaq C700 Touchpad Replacement: passo 16, imagem 1 %32
    • Locate the disk drive on the side of the device.
    • Remove it by pulling it all the way out.
  17. HP Compaq C700 Touchpad Replacement: passo 17, imagem 1 %32
    • Use the PH0 screwdriver to remove the two 3 mm Phillips head screws in the disk drive port.
  18. HP Compaq C700 Touchpad Replacement: passo 18, imagem 1 %32
    • Disconnect the touchpad connection using the tweezers.
  19. HP Compaq C700 Touchpad Replacement: passo 19, imagem 1 %32
    • Use the plastic opening tool to pry up all sides of the device cover.
  20. HP Compaq C700 Touchpad Replacement: passo 20, imagem 1 %32
    • Remove the cover by lifting it.
  21. HP Compaq C700 Touchpad Replacement: passo 21, imagem 1 %32
    • Use the PH0 screwdriver to remove the six 1 mm Phillips head screws surrounding the touchpad
  22. HP Compaq C700 Touchpad Replacement: passo 22, imagem 1 %32
    • Use the tweezers to remove the touchpad wire connection.
  23. HP Compaq C700 Touchpad Replacement: passo 23, imagem 1 %32 HP Compaq C700 Touchpad Replacement: passo 23, imagem 2 %32
    • Use the plastic opening tool to pry up the touchpad cover.
    • Lift and remove the touchpad cover.
  24. HP Compaq C700 Touchpad Replacement: passo 24, imagem 1 %32
    • Use the blow dryer to melt the adhesive around the edge of the touchpad.
    • The touchpad is now free to be removed.
Conclusão
Uma outra pessoa concluiu este guia.
Taylor Johansen
Membro desde: 10/20/16
690 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 5-6, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-6, Martin Fall 2016
UMASSD-MARTIN-F16S5G6
3 Membros
Autoria de 6 guias
Um comentário
I need Compaq laptop c700 Touch pad
So how can I get it?
Suraj Verma - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 1,413
