Ir para o conteúdo principal
HP Compaq C700 Key Replacement
O que você precisa
  1. HP Compaq C700 Key Replacement, Key: passo 1, imagem 1 %32
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pushing and holding on the power button located above the keyboard.
  2. HP Compaq C700 Key Replacement: passo 2, imagem 1 %32
    • Position the opening tool under the edge of the key.
    • Gently pry up one side of the key until the key pops out of place.
Conclusão
Taylor Johansen
Membro desde: 10/20/16
690 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 5-6, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-6, Martin Fall 2016
UMASSD-MARTIN-F16S5G6
3 Membros
Autoria de 6 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 386
