Ir para o conteúdo principal
HP Compaq 6710b Wireless Card Replacement
O que você precisa
  1. HP Compaq 6710b Wireless Card Replacement, Battery: passo 1, imagem 1 %32
    • Turn off your computer! Taking out the battery while it's still on is dangerous!
    • Flip the laptop over to the back.
    • Using two hands, push on the tabs while gently taking out the battery.
  2. HP Compaq 6710b Wireless Card Replacement, Wireless Card: passo 2, imagem 1 %32 HP Compaq 6710b Wireless Card Replacement, Wireless Card: passo 2, imagem 2 %32
    • Make sure the computer is off.
    • Using a Phillips #1, unscrew the 5mm screw on the bottom of the laptop
    • Remove the back cover plate.
    • The cover has popping tabs so it might require a small amount of force to remove.
  3. HP Compaq 6710b Wireless Card Replacement: passo 3, imagem 1 %32 HP Compaq 6710b Wireless Card Replacement: passo 3, imagem 2 %32
    • Using a blue plastic prying tool, gently pry off the 2 connectors.
    • The black cable goes on the connection closer to where the cables originate, while the white cable goes on the farther connection.
  4. HP Compaq 6710b Wireless Card Replacement: passo 4, imagem 1 %32 HP Compaq 6710b Wireless Card Replacement: passo 4, imagem 2 %32
    • Using the Phillips #1 screwdriver, unscrew the 2 3mm screws.
    • Adaptor is spring-loaded.
    • You can now take out the adaptor.
Conclusão
Khulan Orgil
Membro desde: 04/14/15
1.171 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 4-2, Maness Spring 2015 Membro de Cal Poly, Team 4-2, Maness Spring 2015
CPSU-MANESS-S15S4G2
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 29
Ao todo: 2,810
