Introdução
Replace your screen quickly and easily!
O que você precisa
Flip the laptop over to the back.
Using two hands, push on the tabs while gently taking out the battery.
Flip to the backside of the laptop.
Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
Using the same screwdriver, unscrew the 8mm screws.
Using a flathead screwdriver, work both sides of the connector next to the fan and take it out.
8 outras pessoas executaram este guia.
