Ir para o conteúdo principal
HP Compaq 6710b Power Button Panel Replacement
O que você precisa
  1. HP Compaq 6710b Power Button Panel Replacement, Keyboard: passo 1, imagem 1 %32 HP Compaq 6710b Power Button Panel Replacement, Keyboard: passo 1, imagem 2 %32 HP Compaq 6710b Power Button Panel Replacement, Keyboard: passo 1, imagem 3 %32
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
  2. HP Compaq 6710b Power Button Panel Replacement: passo 2, imagem 1 %32
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
  3. HP Compaq 6710b Power Button Panel Replacement: passo 3, imagem 1 %32 HP Compaq 6710b Power Button Panel Replacement: passo 3, imagem 2 %32
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
  4. HP Compaq 6710b Power Button Panel Replacement: passo 4, imagem 1 %32
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
  5. HP Compaq 6710b Power Button Panel Replacement, Power Button Panel: passo 5, imagem 1 %32
    • Put a finger under each side of the plastic lock on the ribbon cable and pull up.
  6. HP Compaq 6710b Power Button Panel Replacement: passo 6, imagem 1 %32 HP Compaq 6710b Power Button Panel Replacement: passo 6, imagem 2 %32 HP Compaq 6710b Power Button Panel Replacement: passo 6, imagem 3 %32
    • Using a flathead screwdriver, get under each plastic hinge cover until they pop.
    • Lift the right edge of plastic strip covering the power button and gently pull it up until the whole strip comes free.
Conclusão
4 outras pessoas executaram este guia.
Khulan Orgil
Membro desde: 04/14/15
1.171 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 4-2, Maness Spring 2015 Membro de Cal Poly, Team 4-2, Maness Spring 2015
CPSU-MANESS-S15S4G2
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 3,575
