Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Flip to the backside of the laptop.
Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
Using the same screwdriver, unscrew the 8mm screws.
Flip over the laptop to the top side, and open the laptop.
Slide the locking tabs down using a blue plastic opening tool or your fingernail.
Using the plastic prying tool, lift the keyboard gently towards you.
Pull up on both sides of the black locking tab of the connector.
The keyboard should now be free of the computer.
4 outras pessoas executaram este guia.
2 comentários
Did you really need to be told to get a keyboard part to do a keyboard replacement?
Thanks for the guide
