Ir para o conteúdo principal
HP Compaq 6510b Hard Drive Replacement
O que você precisa
  1. HP Compaq 6510b Hard Drive Replacement, Battery: passo 1, imagem 1 %32 HP Compaq 6510b Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Flip the computer over so the backside is facing you.
    • Using the two prongs that are located in the back, slide the further left prong and the upper right prong to the left as indicated in the image.
    • Slide the battery out.
  2. HP Compaq 6510b Hard Drive Replacement, Hard Drive: passo 2, imagem 1 %32 HP Compaq 6510b Hard Drive Replacement, Hard Drive: passo 2, imagem 2 %32 HP Compaq 6510b Hard Drive Replacement, Hard Drive: passo 2, imagem 3 %32
    • Flip the laptop over and locate the sign that says HP 3D DriveGuard.
    • Remove the two 5mm JIS #1 screws with your screwdriver.
    • Carefully lift up the cover.
    • Carefully lift up the hard drive from the back and pull it out.
Conclusão
Joseph Noudom
Membro desde: 03/01/18
569 Reputação
Autoria de 4 guias
Equipe
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 28
Ao todo: 1,005
