Ir para o conteúdo principal
HP Compaq 515 Wireless Card Replacement
O que você precisa
  1. HP Compaq 515 Wireless Card Replacement, Hard Drive: passo 1, imagem 1 %32
    • Flip the laptop over to the backside. The Hard Drive is located on the bottom left.
    Pergunte ao FixBot
  2. HP Compaq 515 Wireless Card Replacement: passo 2, imagem 1 %32
    • Unscrew the two screws with a PH00 bit. This releases the hard drive.
    • The screws are held in place, so there is no need to worry about losing them
    Pergunte ao FixBot
  3. HP Compaq 515 Wireless Card Replacement: passo 3, imagem 1 %32
    • Slide the hard drive case off in a horizontal motion away from the device to remove the hard drive.
    Pergunte ao FixBot
  4. HP Compaq 515 Wireless Card Replacement, Wireless Card: passo 4, imagem 1 %32
    • The wireless card is located on the bottom of the laptop, however the hard drive case must be removed in order to access the wireless card.
    Pergunte ao FixBot
  5. HP Compaq 515 Wireless Card Replacement: passo 5, imagem 1 %32
    • Unscrew the two screws holding the hard drive in place, using a PH00 bit.
    Pergunte ao FixBot
  6. HP Compaq 515 Wireless Card Replacement: passo 6, imagem 1 %32 HP Compaq 515 Wireless Card Replacement: passo 6, imagem 2 %32
    • Slide the wireless card backing towards you to remove it from the laptop.
    Pergunte ao FixBot
  7. HP Compaq 515 Wireless Card Replacement: passo 7, imagem 1 %32
    • Gently remove the black and white wires that are connected to the wireless card.
    • The wires are held firmly in place, so it may take some force to remove them. Be cautious when doing so as the wires may tear or fray
    Pergunte ao FixBot
  8. HP Compaq 515 Wireless Card Replacement: passo 8, imagem 1 %32
    • Remove the two .4 cm screws with a PH00 bit.
    Pergunte ao FixBot
Conclusão
Aleks B
Membro desde: 03/19/18
337 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 57
Ao todo: 492
