Ir para o conteúdo principal
HP Compaq 515 Keyboard Replacement
O que você precisa
  1. HP Compaq 515 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Turn the laptop over, the screws for the keyboard are in the middle and left of the device
  2. HP Compaq 515 Keyboard Replacement: passo 2, imagem 1 %32
    • Unscrew the two 0.725 cm Screws with a PH1 screwdriver bit
    • Make sure to put the screws in a safe place so you don't lose them
  3. HP Compaq 515 Keyboard Replacement: passo 3, imagem 1 %32
    • Flip the laptop over and open the screen
  4. HP Compaq 515 Keyboard Replacement: passo 4, imagem 1 %32 HP Compaq 515 Keyboard Replacement: passo 4, imagem 2 %32
    • Gently use a plastic spudger to remove the plastic holder at the top of the keyboard
  5. HP Compaq 515 Keyboard Replacement: passo 5, imagem 1 %32
    • Gently use a plastic spudger to remove the keyboard from its holders
    • Be careful as there is a wire connecting the keyboard to the laptop
  6. HP Compaq 515 Keyboard Replacement: passo 6, imagem 1 %32
    • Carefully unclip and remove the large black wire that is connecting the keyboard to the laptop
Conclusão
Kirsten Harnden
Membro desde: 03/13/18
259 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 407
