Introdução
This guide requires only two screws to be removed with Phillips head screwdriver. Once the panel is removed, the ram can easily be pulled out.
O que você precisa
Flip the device over so the back panel is facing upwards. Locate the RAM plate cover towards the left side of the laptop. There will be two screws located on the panel.
