Ir para o conteúdo principal
HP Compaq 2510p RAM Replacement
O que você precisa
  1. HP Compaq 2510p RAM Replacement, RAM: passo 1, imagem 1 %32
    • Flip the device over so the back panel is facing upwards. Locate the RAM plate cover towards the left side of the laptop. There will be two screws located on the panel.
  2. HP Compaq 2510p RAM Replacement: passo 2, imagem 1 %32
    • Remove both screws holding the RAM cover plate in place using your Phillips Screwdriver.
  3. HP Compaq 2510p RAM Replacement: passo 3, imagem 1 %32
    • Remove the cover plate by lifting upwards once screws are removed.
  4. HP Compaq 2510p RAM Replacement: passo 4, imagem 1 %32
    • Carefully release the pins that are securing the RAM in place by pushing in a outward motion, away from the RAM.
    • Be sure to ground yourself before touching the RAM.
    • Be gentle when releasing the pins.
  5. HP Compaq 2510p RAM Replacement: passo 5, imagem 1 %32
    • Remove the old RAM by lifting it upwards, then pulling.
Conclusão
Nathan Pereira
Membro desde: 10/26/16
57 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 3-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G8
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 14
Duração total: 772
