Ir para o conteúdo principal
HP Compaq 2510p Bluetooth Adapter Replacement
O que você precisa
  1. HP Compaq 2510p Bluetooth Adapter Replacement, Bluetooth Adapter: passo 1, imagem 1 %32
    • Place the laptop upside down, with the battery facing away from you. Towards the bottom-middle of the laptop, you should see a small panel with a Bluetooth symbol.
  2. HP Compaq 2510p Bluetooth Adapter Replacement: passo 2, imagem 1 %32
    • There is 1 screw on the panel you located in step one. Use your Philips head screwdriver to remove the single screw.
  3. HP Compaq 2510p Bluetooth Adapter Replacement: passo 3, imagem 1 %32
    • Remove the Bluetooth panel by pulling it with your finger.
    • Pull gently as there is a wire connecting the laptop and the adapter.
  4. HP Compaq 2510p Bluetooth Adapter Replacement: passo 4, imagem 1 %32
    • Pull the adapter to the left exposing its underside. Locate and remove its only screw using your Phillip's head screwdriver.
  5. HP Compaq 2510p Bluetooth Adapter Replacement: passo 5, imagem 1 %32
    • Separate the Bluetooth adapter by pulling it from its casing.
  6. HP Compaq 2510p Bluetooth Adapter Replacement: passo 6, imagem 1 %32
    • Remove the adapter by pulling on the base of the connecting wires and the adapter, in opposite directions.
    • Use moderate force.
Conclusão
3 outras pessoas executaram este guia.
Derek Kohansky
Membro desde: 10/26/16
297 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 3-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G8
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 403
