Ir para o conteúdo principal
HP Color LaserJet Pro MFP M277dw toner cartridges Replacement
O que você precisa
  1. HP Color LaserJet Pro MFP M277dw toner cartridges Replacement, your printer: passo 1, imagem 1 %32 HP Color LaserJet Pro MFP M277dw toner cartridges Replacement, your printer: passo 1, imagem 2 %32
    • find the two notches on the side that allow you to easily open the front panel.
  2. HP Color LaserJet Pro MFP M277dw toner cartridges Replacement, Open the Front Panel: passo 2, imagem 1 %32 HP Color LaserJet Pro MFP M277dw toner cartridges Replacement, Open the Front Panel: passo 2, imagem 2 %32
    • Don't pull too hard as you might break your printer.
    • Pull both notches
  3. HP Color LaserJet Pro MFP M277dw toner cartridges Replacement, pull out the tray that contains the toner cartridges: passo 3, imagem 1 %32 HP Color LaserJet Pro MFP M277dw toner cartridges Replacement, pull out the tray that contains the toner cartridges: passo 3, imagem 2 %32
    • pull on the BLUE handle.
  4. HP Color LaserJet Pro MFP M277dw toner cartridges Replacement: passo 4, imagem 1 %32 HP Color LaserJet Pro MFP M277dw toner cartridges Replacement: passo 4, imagem 2 %32
    • take out your printer cartridges one-by-one.
    • dispose properly!
  5. HP Color LaserJet Pro MFP M277dw toner cartridges Replacement: passo 5, imagem 1 %32
    • beware that there are little markings in each slot that says the color DO NOT MIX THESE UP
    • do not mix the cartridges up
    • do not touch the blue/green roller on the bottom of your new cartridges.
  6. HP Color LaserJet Pro MFP M277dw toner cartridges Replacement: passo 6, imagem 1 %32 HP Color LaserJet Pro MFP M277dw toner cartridges Replacement: passo 6, imagem 2 %32 HP Color LaserJet Pro MFP M277dw toner cartridges Replacement: passo 6, imagem 3 %32
    • put them back in the printer
    • look at the pictures for more info
    • push the tray back and close the front panel
Conclusão
To reassemble your device, follow these instructions in reverse order. or look at the pictures on step 6.
Uma outra pessoa concluiu este guia.
Seizure Salad
Membro desde: 01/12/18
2.356 Reputação
Autoria de 2 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 321
Autoria de 1.469 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 63
Duração total: 2,866
