Introdução
If your printer is improperly taking in your paper through the bottom tray, you may need to replace your rollers. With nothing but a #2 Phillips screwdriver, you will be able to quickly remove them.
O que você precisa
7 outras pessoas executaram este guia.
Um comentário
Thank you!
Should the black roller just behind these two rollers also be replaced?
Best wishes
Mark
