Ir para o conteúdo principal
HP Color LaserJet Pro MFP M277dw Power Module Replacement
O que você precisa
  1. HP Color LaserJet Pro MFP M277dw Power Module  Replacement, Power Module: passo 1, imagem 1 %32 HP Color LaserJet Pro MFP M277dw Power Module  Replacement, Power Module: passo 1, imagem 2 %32 HP Color LaserJet Pro MFP M277dw Power Module  Replacement, Power Module: passo 1, imagem 3 %32
    • Open and lower the back panel by pulling it down.
    • Remove one Phillips #2 10 mm screw.
  2. HP Color LaserJet Pro MFP M277dw Power Module  Replacement: passo 2, imagem 1 %32 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: passo 2, imagem 2 %32 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: passo 2, imagem 3 %32
    • Use the plastic opening tool to remove the right side panel of the printer.
    • Flipping the printer on its side, with the right side facing up, will make it easier to remove.
  3. HP Color LaserJet Pro MFP M277dw Power Module  Replacement: passo 3, imagem 1 %32 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: passo 3, imagem 2 %32 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: passo 3, imagem 3 %32
    • Remove two Phillips #2 12mm screws.
    • Remove four different pin connectors that attach to the power module located at the bottom.
    • Removing the white connector is made easier with assistance of a spudger/flat tip that loosens the clamp.
  4. HP Color LaserJet Pro MFP M277dw Power Module  Replacement: passo 4, imagem 1 %32 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: passo 4, imagem 2 %32
    • Remove two Phillips #2 10mm from the left (front) and right (back) side that attach the power module to the printer.
  5. HP Color LaserJet Pro MFP M277dw Power Module  Replacement: passo 5, imagem 1 %32 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: passo 5, imagem 2 %32 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: passo 5, imagem 3 %32
    • Slowly lift the power module from the printer using both hands.
Conclusão
3 outras pessoas executaram este guia.
Lyndon Fresnido
Membro desde: 10/08/18
184 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S4-G2, White Fall 2018 Membro de Cal Poly, Team S4-G2, White Fall 2018
CPSU-WHITE-F18S4G2
Membros da 3
Autoria de 10 guias
2 comentários
Hello, wäre can i buy the power supply? Thank you
Jakob Hetzendorfer - Responder
Thanks a lot - also works for model M281fdw
patrik maurer - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 60
Duração total: 4,292
