Ir para o conteúdo principal
HP Color LaserJet Pro MFP M277dw Power Button Replacement
O que você precisa
  1. HP Color LaserJet Pro MFP M277dw Power Button Replacement, Power Button: passo 1, imagem 1 %32 HP Color LaserJet Pro MFP M277dw Power Button Replacement, Power Button: passo 1, imagem 2 %32 HP Color LaserJet Pro MFP M277dw Power Button Replacement, Power Button: passo 1, imagem 3 %32
    • Lower the back panel by pulling it down.
    • Remove one Phillips #2 10mm screw.
    • Use the plastic opening tool to remove right side panel by prying it off.
    • Flipping the printer onto its side makes it easier to remove the side panel.
  2. HP Color LaserJet Pro MFP M277dw Power Button Replacement: passo 2, imagem 1 %32 HP Color LaserJet Pro MFP M277dw Power Button Replacement: passo 2, imagem 2 %32
    • Lower the front panel by pulling it down from the upright position.
    • The button cover should come off with the panel, if it does not be sure to remove it.
  3. HP Color LaserJet Pro MFP M277dw Power Button Replacement: passo 3, imagem 1 %32 HP Color LaserJet Pro MFP M277dw Power Button Replacement: passo 3, imagem 2 %32 HP Color LaserJet Pro MFP M277dw Power Button Replacement: passo 3, imagem 3 %32
    • Remove two Phillips #2 8mm screws.
    • Unplug the wire connecting the power button to the circuit board by gently pulling them apart.
Conclusão
Uma outra pessoa concluiu este guia.
Christopher Fahey
Membro desde: 10/08/18
744 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S4-G2, White Fall 2018 Membro de Cal Poly, Team S4-G2, White Fall 2018
CPSU-WHITE-F18S4G2
Membros da 3
Autoria de 10 guias
2 comentários
How to make the catridge tray out ? As one side(left) of the tray is not coming out.
Ajay Kumar Singh - Responder
I am not sure if it’s the power button or power module. How do I determine that? Where do I get the parts?
Sheila Shook - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 45
Duração total: 2,620
