Introdução
If the WLAN Module of your HP Chromebox is damaged, it is easy to replace. This guide will take you through the steps of replacing the WLAN module. For this guide, you will need the Philips #1 screwdriver.
O que você precisa
Position the device upside-down on a flat, level surface with the USB ports facing you.
Quase terminado!
Conclusão
