Introdução
If the hard drive of your HP Chromebox is damaged, it is easy to replace. This guide will take you through the steps of replacing the hard drive. For this guide, you will need the Phillips #1 screwdriver.
O que você precisa
Position the device upside-down on a flat, level surface with the USB ports facing you.
3 outras pessoas executaram este guia.
2 comentários
actually you can flip open metal bracket with just one mylar tape
and there is 5 screws, not 4. if you look, you will see triangle arrow stamped on bracket indicating which screws to remove.
you can swap the ssd without removing the wifi board
do this all the time, saves a lot of steps
