Ir para o conteúdo principal
HP Chromebook x360 14c-ca0053 Screen Replacement
O que você precisa
  1. HP Chromebook x360 14c-ca0053 Screen Replacement, Lower Case: passo 1, imagem 1 %32 HP Chromebook x360 14c-ca0053 Screen Replacement, Lower Case: passo 1, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to apply light pressure on the outer sides of the 2 small screw covers located near the bottom of the device.
    • Rotate the covers until they pop up out of the screw socket enough to remove them with tweezers.
  2. HP Chromebook x360 14c-ca0053 Screen Replacement: passo 2, imagem 1 %32 HP Chromebook x360 14c-ca0053 Screen Replacement: passo 2, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the two 3.5 mm screws.
  3. HP Chromebook x360 14c-ca0053 Screen Replacement: passo 3, imagem 1 %32 HP Chromebook x360 14c-ca0053 Screen Replacement: passo 3, imagem 2 %32 HP Chromebook x360 14c-ca0053 Screen Replacement: passo 3, imagem 3 %32
    • Use tweezers to peel back the feet on the top and bottom of the Chromebook to reveal four additional screws.
  4. HP Chromebook x360 14c-ca0053 Screen Replacement: passo 4, imagem 1 %32 HP Chromebook x360 14c-ca0053 Screen Replacement: passo 4, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the 4 7 mm screws located at each corner of the device under the grips.
  5. HP Chromebook x360 14c-ca0053 Screen Replacement: passo 5, imagem 1 %32 HP Chromebook x360 14c-ca0053 Screen Replacement: passo 5, imagem 2 %32 HP Chromebook x360 14c-ca0053 Screen Replacement: passo 5, imagem 3 %32
    • Insert an opening pick between lower case and chassis.
    • Separate the lower case from the frame by sliding the opening pick along the perimeter until the case releases.
  6. HP Chromebook x360 14c-ca0053 Screen Replacement: passo 6, imagem 1 %32
    • Lift the lower case up and off.
  7. HP Chromebook x360 14c-ca0053 Screen Replacement, Battery: passo 7, imagem 1 %32 HP Chromebook x360 14c-ca0053 Screen Replacement, Battery: passo 7, imagem 2 %32 HP Chromebook x360 14c-ca0053 Screen Replacement, Battery: passo 7, imagem 3 %32
    Comprar
    • Open the tweezers wide enough to fit on each side of motherboard battery connection.
    • Pull the connector directly out of its socket.
  8. HP Chromebook x360 14c-ca0053 Screen Replacement: passo 8, imagem 1 %32 HP Chromebook x360 14c-ca0053 Screen Replacement: passo 8, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the five 3 mm screws that secure the battery.
    • These screws are labeled 1-5.
  9. HP Chromebook x360 14c-ca0053 Screen Replacement: passo 9, imagem 1 %32
    • Lift the battery up and out.
    • Be careful as to not puncture or damage the battery.
  10. HP Chromebook x360 14c-ca0053 Screen Replacement, Screen: passo 10, imagem 1 %32 HP Chromebook x360 14c-ca0053 Screen Replacement, Screen: passo 10, imagem 2 %32
    • Use the opening pick to create a small gap between the back panel of the screen and the display screen.
    • If it is difficult to insert the opening pick between the screen and back panel, use the metal spudger instead.
  11. HP Chromebook x360 14c-ca0053 Screen Replacement: passo 11, imagem 1 %32 HP Chromebook x360 14c-ca0053 Screen Replacement: passo 11, imagem 2 %32
    Comprar
    • Use tweezers to locate the black tape between the back panel and the display screen.
    • Pull the adhesive through the gap on each side of the screen until it comes loose.
    • Replace the adhesive during reassembly.
  12. HP Chromebook x360 14c-ca0053 Screen Replacement: passo 12, imagem 1 %32 HP Chromebook x360 14c-ca0053 Screen Replacement: passo 12, imagem 2 %32
    • Use tweezers to peel back the square-shaped silver tape on the top side of the device.
  13. HP Chromebook x360 14c-ca0053 Screen Replacement: passo 13, imagem 1 %32 HP Chromebook x360 14c-ca0053 Screen Replacement: passo 13, imagem 2 %32
    • Use tweezers to lift up the black metal wire covering the connector.
    • Gently pull the display connector out from the device.
  14. HP Chromebook x360 14c-ca0053 Screen Replacement: passo 14, imagem 1 %32 HP Chromebook x360 14c-ca0053 Screen Replacement: passo 14, imagem 2 %32
    • Use the tweezers to lift the gray square with the black wire from the motherboard.
  15. HP Chromebook x360 14c-ca0053 Screen Replacement: passo 15, imagem 1 %32 HP Chromebook x360 14c-ca0053 Screen Replacement: passo 15, imagem 2 %32
    • Remove the screen.
Conclusão
Uma outra pessoa concluiu este guia.
Cassidy
Membro desde: 09/18/23
691 Reputação
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 34
Duração total: 289
